Hi guys,
I'm having a bit of a nightmare running HDMI from my PC to my TV. I'm using the rig below and the TV is a sharp LC-40SH340K. I can get a picture and using overscan it fills the screen but the picture is so blurry. I've heard it's a common problem but usually rectified by renaming then inputs (no feature to do that on this TV).
In the manual it says that you can only use the VGA input for PC but I do not have any VGA ports on the 290 and it only has the DVI standard (one without the extra 4) so I can't use a DVI > VGA adapter to solve this. I'm just trying to work out the best solution.
So far I've tried one of these.
This gave a washed out look and while playing games it would keep getting and losing signal. I had to change the pixel format to RGB 4:4:4 to get that to fit properly as well. It was only £8 so could have just been a Chinese poor bit of kit, I don't know.
My next idea is to try one of these:
(I have no idea if this will rectify the fact that the TV wants the input coming though the VGA port though)
I have the other option of going for one of these
or one of these....
(Happy to run VGA if needs be)
Just wanted some advice really and to see if anybody else has had similar issues and found the ideal fix.
Cheers (sorry for wall of text)
or one of these....
