TV Audio through Z-5500 Speakers?
Caporegime
1 Oct 2004
Redcar
Is this possible, I would have really thought so.
The TV is the Samsung LE32R41BD which has your Phono L/R (White/Red) audio out sockets.
Is there any convertor to convert from these cables into a coaxial signal? (PC Inputs / Coaxial and Optical on the reciever) Optical is taken up by the Xbox360.
Any help on how this would be possible would be awesome. Thanks.
Karl.
It's a volume control which has the inputs, I suppose it would be comparable with the set top box with the Audigy 2 ZS Platinum Pro.
A wanted to go through coaxial, but a Phono > 3.5mm jack may be the best bet.
Coax is a digital only connection. There is a line-in on the side of the z5500 decoder unit that can be used (tv phono to stereo minijack). I use this for the psp currently ;)
