TV Card advice
9 Oct 2005
Just looking for some advice on a TV Card, so many out there!
Can anyone recommend some good cards\brands?
I will be moving to university and wont be able to fit my 21" tv and the tft in the room sensibly so I will be using my PC as the TV.
I need it to be compatable with digital, preferably with digital radio (not essential). PCI is fine, however usb would be nice for when I get my laptop.
my sister has loads of problems with a digital TV card while living in halls... terrible infact... I wouldnt recommend it if going into halls
Stelly
Is your sister using a seperate arial or the main halls one?
If it really is that bad might be worth looking for a dual analogue\digital (at least you can still watch the analogue even if its fuzzy)
Any of the Leadtek cards are very good, i have the Leadtek Winfast DTV1000-T Digital TV Tuner Card, and its a great performer and PVR to boot.
