I have a Hauppauge WinTV-HVR-1300-MCE card and running Windows 7. When I installed windows 7 it automatically installed several drivers. I have not yet installed any other software to make use of the card.
In Gibraltar, I am not sure why, our reception of digital channels is DVB-C even though most of the TVs and hardware we get (which usually comes from Spain or UK) is DVB-T. When I bought the card and my TV, I had no idea about this and both are DVB-T.
So I was told a good solution was to get an external DVB-C receiver and hook that up to the TV and the TV Tuner.
I bought a Technisat DIGIT K3X (http://www.technisat.com/indexa630.h...B_C_,en,67-433) and have set it up on my TV, found the channels, etc. However, I am not sure how to hook it up to the card and how I would go about capturing video in order to record programmes. My main aim is to be able to schedule recordings of programmes I usually miss when I am out.
I have a converter of some sort that is SCART on one side and has 3 connections on the other, yellow (video) and red/white (audio). Is it just a question of connecting the SCART of the Technisat box (labelled VCR) to the TV card using that?
Would software such as Media Center or other PVR software be able to show the channel being selected on the box and record it? I guess by using the card just as a capture card not not the tuner I would lose the ability for the recording schedule to choose the actual channel right?
