TV Card Required!
16 Jun 2006
Bournemouth, Dorset
Hi can anyone recommend a decent tv card for vista x64 budget not really an issue, would prefer a pci-e model though. Any advice anyone could offer would be greatly appreciated. :)
Terratec Cinergy 2400i DT DVB-T TV Tuner I would definetly consider if you can afford the cost of it as it's quite expensive. Was looking into this card a while back for a replacement to my Nebula DigiTV PCI card which doesn't work in Vista x64 and only didn't buy it as I moved back to Windows XP until Vista SP1. I could never find a bad review of this card and it seemed extremely good.
I've got one of these. Fantastic picture, brilliant driver support, home cinema software a bit iffy, but bearable. Definately worth the £69 I paid for it;)
