I've wired my house with Cat6: 4 sockets in each of the 3 bedrooms and 2x4 (a set in each alcove, in case I want to rearrange the AV) in the front and rear reception rooms.
It all goes to a patch panel/giga switch underneath my stairs.
It was now my intention to lay coax to each room for Freeview HD. However, I find myself wondering if there is any way to avoid the expense of buying coax, laying it and knocking more holes in the walls (for a socket) and utilise the ethernet cable instead?
I was thinking some sort of solution whereby I have a box in my cabinet under the stairs where the coax from the roof aerial goes and then this in turn feeds any of the ethernet sockets in any of the rooms, via my patch panel?
