TV or Monitor for PS5
21 Apr 2012
Thinking of buying a new monitor/TV around 27" for my PS5.
Planning on moving it downstairs so I can just chill on it on the sofa whilst big TV is being used for other stuff.
Would a TV or a monitor be best? It's very unlikely to be used for anything other than PS5 gaming.
Probably don't want to spend much more than about £250~ as I suspect it will end up not getting all that much use long term!
Personally I'd just pick up a 27" Monitor.
Most decent monitors will do the 120hz that is the maximum the PS5 can output (usually in performance mode), so just a case of choosing what resolution you'd prefer - either 1080P, 1440P or 4K :)
1080 is probably fine id say.
Any specific recommendation?
Would there be a 32” equivalent, just in case I can make the space work.
