I'm looking for a new 4k TV around 40". All I need is a good screen, the rest is redundant. Budget £500.
- I do everything through my HTPC, it has a satellite tuner, handles TV recordings and I play everything through it, can stream from it, etc. I'm not going to use any "Smart" features and don't even need a TV tuner in the TV.
- I have a decent soundbar so inbuilt audio is also redundant.
I'm currently using a 10 year old, low end when it was new, 1080p flatscreen TV so anything would be an upgrade and I don't want to spend thousands.
Am I better off getting a TV or looking for a 40" PC monitor? My initial thought was that a £500 PC monitor you are just paying for the monitor so would get a better panel but then I realised that 40" monitors don't have the encomies of scale that TVs do so that might not be the case.
