TV Output Quality
27 Dec 2004
Staffordshire
Hi,
I currently have a pretty standard amd athlon setup with a pny 6600gt gfx card, i tend to watch a lot of avi files from the computer on my panasonic crt widescreen tv using a composite video cable from the svideo port on the back of the gfx card (with a svideo - composite conveter which was supplied with the gfx card). the picture quality generally seems crap compared to the computer monitor. i also tried burning some avis to a dvd and played them on my gfs avi compatable dvd player and the picture quality from that is superb. any sggestions on how i can improve the pic quality using my composite cable?
thanks, russ
thought that may be the case to be honest. just thought id ask as theres sometimes tips and tricks within windows that someone has found which would result in a much better quality.
thanks for taking the time to reply, russ
