TV recommendation please!
8 Jan 2007
Barcelona
Hi,
I've got 600 euros/pounds to spend on a new tv, has to be 55", had an LG plasma for the last 12 years which is still going strong and would ideally like to buy again from them.
TV is mostly used for gaming and tv in a very bright space, hooked up to speakers so internal speaker quality isn't important.
Can anyone suggest a TV that meets those criteria? Thanks!
Samsung 55" Q95TD can be had for just over £500 atm
Won't get the same blacks as you're used to with the plasma but would handle the bright room well
