TV related - what sort of cable is this?
10 May 2004
Sunny Stafford
My house has recently been re-wired and I got myself a TV for the first time. I think I have found 2 aerial points but my TV aerial cable doesn't fit into either of them (male or with female adapter). I don't think it's the old NTL cable point either because I know where that is as it's in a different part of the house. If it turns out I don't have a TV aerial point, what would be the best options to receive Freeview? Freeview itself is built into the TV so that bit is sorted. Cheers :-)
As above, dual coax cable with F-plug connections. Connected to a sky dish that may or may not still be mounted outside your house.
If no aerial socket, easiest way to get freeview would be to buy a portable aerial, although this depends on quality of signal in the room your TV is in.
Looks like a right bodge job. NTL/Virgin media would have put a faceplate or a box there, not cables coming out of the wall. In the old day it would have been two cables though - one for the TV box (e.g. Tivo) and a separate one for the cable modem. I'm guessing a previous owner has taken the box off and bodged it up.
Sky generally just cable straight from the dish, through wall and into sky box.
As others have said it’s 100% for a satellite dish, probably Sky. You can use them with a FreeSat box though.
It’s two cables for two tuners (watch one, record another).
They can easily be extended if you want to re-use them as they look pretty short.
They look rather thick and quite rigid for Sky? The shotgun cables are thinner than that and quite pliable. Though I remember one time in 2008 when they used to install two separate cables, they were once thick.
I think they are really old. The cables at our old house were like that. (From a previous install)
Thanks guys!
Yes I can confirm there is a satellite dish outside my house, on the opposite side of the wall pictured in my OP. I won't sign up to any TV packages (Sky, BT etc) as I already have Prime and Disney+ but will see what I can do with the Sky cables. Will I still need to get a Sky box or is there a converter that I can get for the Sky cables that can link to my TV?
Yeah, I moved here in 2006 and just never bothered with a TV until now. It was the Euro football from last year that made me want to get a telly for the first time and went all-out for a 65" Philips Ambilight :D
Looks like a sky cable from the sky+ days.
Where does the cable go? Do you have a dish on the wall or see evidence of one being removed.
Edit: Already answered above
To think once, Sky HD was so pin sharp back in 2007/8/9. I remember all the rave hearing about it in 2006 for people coming from Sky Plus. A film recording could be 9 - 11GB back then.
Freesat box is the best option, probably about £50 for one that cant record and maybe £150-£200 for one that can.
You could get a free sat box. That would make use of the dish :)
I just checked my manual, and it looks like it's already built into my TV?! It also mentions DVB-T2 and F-type cables from posts further up this thread. Shall I try getting an F-type cable/extension from Amazon and see if it works? Then worst case scenario is that I'll just need to book a technician to re-align my satellite dish.
Shall I try getting an F-type cable/extension from...
Yep, shouldn't cost you more than a tenner!
Alignment should be the same as sky.
As you were initially trying to connect an aerial, I assume you have this covered, but you DO need a TV license for FreeSat ;)
(this the reason I've never bothered hooking mine up, despite specifically buying a TV with support when I moved here)
Twin satellite feed one for live one for recording ought to be fine for Freesat a superior option to Freeview
If the TV has a satellite tuner should be case of just plugging it in (with an extension for the lead(s)) you can buy them already made up can't remember where I bought mine amazon possibly
Thanks, and thanks to everyone else as well!
My mum bought me my first year's worth of TV license, so I'm sorted there and have watched a bit of iPlayer so far. I also get the blind person's discount, so £80 here, because I'm a blind git (almost).
I have ordered a pair of F-type cables - female at one end to fit the wall-side male as in the OP then vice versa going into the TV. See how it goes :-)
