Tv stand recommendations
8 Aug 2013
Stoke-On-Trent
Looking to pick up a new Tv stand as my current one is to small to fit everything on.
Can anyone recommend a decent unit not looking to spend more than £300 and don't really want a glass unit with no back.
Needs to fit:
58" TV
Xbox one x
Pioneer vxs 531
Q acoustic 2000ci
Not overly fussed if the centre speaker sits on top or inside the unit.
this is mine
ikea besta unit with glass top with glassvik doors option came in at £245, one thing to note had too create my own holes in the back where the amp is i used a jigsaw same at the other side lower part hole saw did the job for the wires on that side. there is a smaller one if 1.8m is too long.
