TV stands
5 Apr 2014
Hey all could anybody recommend any decent makes of stands please currently we got 48" samsung and Dali Kubic One Soundbar but the stand is to small for the soundbar on the bottom shelf the Bar is roughly 3 feet in length so would proberly need something 1100mm in length. Or does anybody have them stands that lift the tv up in the air with the bracket attached to the back of the tv which gives the tv the floating effect and if so are they any good? was thinking on something like that but read they can cover some of the connections on the back of the tv?
Something like this
http://www.richersounds.com/product/tv-stands/alphason/chromium-2-cantilever/alph-chro-2-ivo-cant
Yes was looking at them but the only thing is do they cover your connections at the back of the tv? we got the Samsung H6400 and im wondering if this will make wiring difficult with the optical cable
It depends where your connections are of course. I don't have any issues but I only have a couple of cables connected to my TV. Check out the mounting holes at the rear of your TV. On the stand I linked to, the mounting plate juts out about 10cm towards the edge of the TV.
