Tv Tuner and general advice for SFF
5 May 2006
Hi,
What TV Tuner are you guys using if you're using these as home theatre setups?
Is it worth getting an ATI All in wonder ?
USB Add on?
I'm tentatively looking at entering the SFF Club :D so doing my research.
Something else i wondered is if i'm using Windows MCE then do i buy the remote for that? or the tv tuner remote or what?
Finally if you had piece of advice before I embark on my SFF adventure, what would it be?
Cheers
Gommsta
You just need a TV card with BDA drivers for it to work with MCE. I'm using a generic connexant PCI card.
You use the Microsoft remote for media centre.
