Tv Tuner Help
  • Thread starter Thread starter Deleted member 70857
  • Start date Start date
Hi, I have a HTPC downstairs and also a V+ box.
I wanted to know, how can I put the signal of the Virgin box into the HTPC?
Because then I can use MediaPortal to stream the image to other TVs.
Thanks
Yes you can, but only by using an analogue capture card and feeding the output of the Virgin box to the card. The quality will suffer but it's not too bad.
Im so sorry to sound like a n00b. But what is a SVHS connection?
Also just to say Im connecting the V+ box to a TV via HDMI
So will thew TV be able to get the HD signal while the HTPC will get a SD signal, Also I am wondering will it transfer sound as well?
I thought that was what you meant. How will I transfer sound as well?
