Kainz said:Google Nebula Digitv - it's the best there is. Software is awesome to use and feature packed.
mrdbristol said:Avermedia.
AVerTV DVB-T USB 2.0
MCE compatable + HDTV Ready.
Signal strenth is vital for all Freeview boxes.
Cheers,
Mark
bbreezeuk said:ive heard good things about the msi one but you would have to confirm it with someone that owns one
Shocky-FM said:Just bought this, got it home and the software will not even start... installed the software and driver and nothing working.... A loading screen comes up and the software doesnt start.. Yes its in a USB 2.0 port.. Sooo not impressed so far...![]()
mrdbristol said:I feel guilty now !!![]()
" A loading screen comes up " for What ? ( the installation sofware or the tv program software )
What Software version did you get with it ? I'm using Version 6.0.2.45 .
Is there a Blue Light on the Box ?
Connected to External Aerial.
( Watching the footy as I type , perfect ( Sorry , not rubbing it in ! ) )
Cheers,
Mark
mrdbristol said:Do you get an icon in the taskbar ?
If its in the task manager , it's running
Is there a light on the usb box ?
Cheers,
Mark
if you are using a signal booster its not always best to have it on the max setting try turning it downShocky-FM said:Another problem, although I do get all channels though none of them seem to be watchable, u get one channel working and then another one stops... and this is with an amplified aerial !... My freeview bot can get every channel clear with just bog standard aerial and thos pos can't get bugger all with amplified one..... its driving me nuts trying to get all the channels though...![]()
