TV Upgrade
Is there a risk of burn in on an Oled, watching football e.g. the static image displaying the score?
The newer oled tvs have pixel shift technology and other features to reduce the chance of screen burn.
What sort of budget do you have and what size screen are you thinking of?
48” - 55” Budget is about a £1000 although I can probably stretch to the price of an LG C1
A 20 sec search on the Rainforest and there were 3 OLED 55" TV's for under £1000 on the first page. And a couple that were £100 over
For your budget you can easily get a 55" C1(Well if you can still find one). I just bought mine from RGB Direct but i believe it was the last one in stock and that was £968 delivered. Worth every penny, great TV. That said unless you are playing PS5 @4K 120Hz you will probably be fine with one of the slightly lower spec LG OLEDS.
