Tv's with low input lag and 100hz pc support do they exist?
9 Mar 2011
I'm reasonably new to understanding what todays tv's can do for pc gaming.
I do know however that input lag needs to be low (below 40ms is acceptable.)
I'm looking for a TV sized between 47-55 that has both low input lag and support 100Hz PC input or ideally 120Hz.
Do these actually exist yet or are we still confined to 60hz PC input.
If they do exist could someone be so kind to recommend a module please - Having 3D support also would be something I'd prefer as an option.
Thanks
Edd
edited..
Game Mode is available on all current Samsung TVs. When you set a video source (input) to Game mode, your TV electronically bypasses two of the video signal processors in the TV, subsequently cutting down the amount of time the TV needs to process the video input from your game. You may notice a slight difference in the picture, but after you implement Game mode there should be reduction of any lag between the game system and the TV.
I am looking into refresh, as most are above 60, but I don't know if this equates to more than 60 FPS.
-further edit
OP what is your output source?
PS4 XBONE PC?
Not something I've extensive knowledge of but seems to be a lack of input lag/pixel response testing on TVs in general. Most if not all only support true 60Hz from a PC even if they say they can do 100+Hz.
As above some have a gaming mode that reduces input lag significantly - though most still have 30+ms lag.
EDIT: This thread here includes a little more info and has a link to a site that does testing on the better TVs http://forums.overclockers.co.uk/showthread.php?t=18565656
