tvv signal question
28 Mar 2004
Im basically moving into a new uni house next month. The only problem is, i'm one of 2 rooms that doesnt have an aerial and I want to know, is there a way I can wirelessley get a signal to my tv in my room, from say and aerial socket in another room?
ive read about these wireless tv senders, but im presuming you need a tv to send it, and it only transmits what the tv is watching? Any chance theres something similar that transmits the entire signal from an aerial connection, wirelessly?
You best bet is to either look into or get someone in who can fit a TV point for you.
The wireless AV senders can only send a single output, usually from scart.
I guess you could use a VCR as a modulator and that would work, but seems a bit long-winded.
