Tweek my spec?
4 Mar 2010
Hi chaps, could you please have a look at the items I have picked for my upgrade; I'm looking for the best bang for buck. Do you think there's anything I should swap out?
GPU
CPU
Mobo
Ram
What do you think?
Brilliant although it doesn't show a comparson of the H60 it is quieter then the H70 and there's only a few degrees if the tempwise.
So I shall go for the cheaper option :)
So guys after this tweak I am a pound and a penny better off with a better build!
I am currently running on a A8N SLi deluxe 3500 venice core with 3 gigs of ram and a 8600gt I won't know myself when it's built!
Thank you! :D
600w Enermax Noisetaker, I'm not sure what the model is but I remember spending a lot on it at the time because I was planning on going SLI.
That should be fine for this spec, but neither the motherboard nor it are up to the task of sli.
My heart stopped for a moment thinking that it would not be up for the task.
Yeah I don't plan on getting an SLI setup this time, good thing I thought ahead though else I may of needed to add a PSU to the list too.
Yea sorry i missed that just saw op's cart, quickly scanned down the thread saw something about ram being fine and thought id better jump on it before op pressed the buy now button ;)
Op pointed that out anyway so its all good better safe than sorry right :D
P.S Note to self read more thoroughly next time ;)
