Having a bit of trouble with Twig.
I have a view template like this
In my controller I have something like
The above works
However I am converting a lot of files where they use php logic.
So Id want to do something like
This is a simple example but Id have things like <?php if true echo "something" else echo "something else" ?>
Is this do able just passing it in like I am trying to or would I have to look at a different approach.
Code:
<td>
<p> {{ paragraph }} </p>
</td>
Code:
$view->setParagraph('What I type here will appear in the view');
The above works
Code:
$view->setParagraph("<?php echo 'Foo: ' ?>"); //this just prints <?php echo 'Foo: ' ?>
$view->setParagraph('<?php echo "Foo: " ?>'); //this just prints <?php echo "Foo: " ?>
When really I want it to display Foo
