twin cards in sli and using rivatuner
3 Jan 2009
Got both my 8800gt in and running and was using rivatuner on the single card and now with it in sli is there any settings etc that need to be activated etc now its running sli, running 700/1750/990 but not sure if its clocking both cards or just the one
cheers Dave
Hmmm not sure, should work on both cards mate, if your not experiencing any difficulties i would leave it, could always just reinstall rivatuner with both cards already installed if you wanted :p
get GPU-z it will show the clocks for both cards and if they are different check with everest - if both show the clocks to be different then the second card is nothing being overclocked (with some cards you will need to check in 3D mode).
Its unfortunatly quite common with SLI :| I've had to BIOS flash the clocks to cards before to ensure they are both running proper clock speeds.
