Getting a case together, atm i have
intel 14900k
asus dark hero board
and 2 ek res loop combo 300ml
gfx card already with a waterblock.
lian li 3000v2 case 2x 480 rad with lian li push pull using there rgb box that i got with them ( 16 fans)
Case will be mounted to the wall to the side of desk on the left ( i have everything for that)
Things i have not thought of till now.
I want to run 2 loops as i have plenty of space
I want ti buy
But,
I was looking at
Bykski B-TFC-CS-X PC Liquid Cooler Flow meter Thermometer Flow Rate Temper 3 In 1 Water Cooling Monitor Digital OLED Display
for each loop for flow and water temp, but i will not be able to put that on the 7 inch screen becuase it doesnt connect to anything.
Also on the motherboard it only has
Fan and Cooling related
1 x 4-pin CPU Fan header
1 x 4-pin CPU OPT Fan header
1 x 4-pin AIO Pump header
4 x 4-pin Chassis Fan headers
1 x W_PUMP+ header
1 x 2-pin Water In header
1 x 2-pin Water Out header
1 x 3-pin Water Flow header
So i think i can run a splitter on the w pump header as i want both pumps to run at hte same speed.
But i do not know if/how to connect something that has a flow and temp senser to the board so i can put in on the little screen.
I asume if i only run 1 loop it would be no issue, but i do want to run 2 loops, just becuase i can.
Any ideas
intel 14900k
I want ti buy
EKWB Quantum Lumen 7in LCD Screen
This screen i will use on my desk for all the info going on with my case.But,
I was looking at
1 x W_PUMP+ header
Any ideas
