Twin watercooling loop,worth the hassle ?
17 Jun 2003
Scotland
Right here goes.I'm about to change my watercooling set up,but had an idea :D
I was thinking of running two loops,one for my X1900XT & one for cpu. I am going to use a 120.1 rad & my MCP350 for the gfx with 3/8 ID tubing,then change my cpu to 1/2 ID using either a dual rad or i have a brand new heater matrix from a fiesta lying around with a DD4 pump.
Would this be worth the effort,or would i be better just running one loop all with 1/2 ID.What would be better the 120.2 or the heater matrix ?
The 120.1 will be mounted on my case using a radbox & the heater matrix or 120.2 will be outside the case.
Any suggestions,just really wondering if it's worth the effort
Rob
prob be a waste of time, id say if your doing a gpu and cpu run it on the 120.2, i ran sli and cpu off 1 n my temps were very nive so i think be your best bet.
