Third Opinion said:Twin Webbers on a 1.4 VW?
Errr ok.
Probably better with a single decent size Webber on that engine. A lot less hassle to set up and cheaper.
ShakenNstirred said:just get a better car
Phil W said:Yeah think the General jist (correct me if i'm wrong) would be to replace the standard carb with a Webber one, you would still need the Inlet etc though iirc.
I've got a webber carb sat in my shed, been there for 3 years now![]()
Phil W said:The carb would fit, but you would need to purcahse your own Inlet for it to mate it up!
Don't know what its worth, ill do some research, won't want much for it, beer tokens and postage paid for will do me
/edit infact i could send it up to Camberley with my Uncle when he next visits (at least once a month)
Lopéz said:Wow, some typically OcUK comments in this thread....
Twin 40 DCOE Webers are ideally suited to a revvy 1.4 like the Polo, but he'll need linkages and an inlet manifold to match. It's also wise to fit an uprated pum, you can often find these cheap on ebay, a Facet should do the job if you can find a cheap one.
Of course, if he is just on about swapping the standerd (Pierburg?) carb for a Weber replacement then it may even be able to use the same manifold, they often do.
Sam said:yea cheers for that nobhead ill let him know
Sam said:Phil if you could dig it out and let me know what it is, i mentioned it to him tonight and he seems very intrested !
