I hate being a re-link bitch, but just been made aware of this by one of my customers, and thought it worth passing on as searching for it turns up nothing.
Twixtor is a Final Cut Pro plugin [Edit: And After Effects, thanks Chuchulain/Ksanti] that allows you to take video (best in HD obviously) and slow it down to hundreds of frames per second. It "fills in the gaps" automatically (and actually quite well, with little artifacting or morphing, considering the prices we're talking), allowing you to use your 5d MKII or Nikon equivalent to film super-slomo high def video.
Twixtor:
http://www.apple.com/downloads/macosx/finalcutstudio/twixtor.html
Here's a Vimeo example of a guy shooting with his 550D (consider we're talking entry level DSLR here):
http://vimeo.com/16340475
Noticed he mentioned that in future he will use cleaner, less busy backgrounds as some morphing is visible but otherwise the results are, in fairness, exceptional. Considering the 550D films at 60fps, it really is rather good.
Go, minions. Create masterworks and report.
Twixtor:
