Two build specs needed
22 Oct 2008
Lisburn
i3 and i5 spec needed.
Don't need screen, OS , Keyboard or Mouse
DO need....
SSD - 120gig would be fine as it's not for gaming - general use only
mobo - won't be overclocking the cpu so any board that is compatible
cpu - i3 or i5 needing both specs
psu - would 450 or 500w be sufficient yes?
case - black and no lights/bling
cpu cooler - not overclocking the chip so would stock be ok or a dedicated one needed?
DVD drive - disc drive/burner needed, it's for older peeps to use
Main use is browsing with some light editing - They have asked me to look at the cheapest i3 and i5 setup. Budget is as low as possible.
Anyone fancy a crack at this? Any other info needed????
Here are two builds, the only difference would be the cpu. 450w would definitely be enough given you aren't planning to use a graphics card.
My basket at Overclockers UK:
Total: £361.51
(includes shipping: £11.70)
And the build with an i5
Total: £421.51
