- 8 Sep 2015
Hello everyone, I'm going to be building myself a machine for VR gaming in November. This is going to be done in two parts - tha main rig in November and the GPU in May next year, with me using the on-board GPU until then.
I've narrowed it down to two choices:
1) Intel Core i7 4790K CPU
Noctua NH-D15 CPU Cooler
Gigabyte Z97X Gaming 3 Motherboard
16GB HyperX Fury 1866MHz DDR3
CM Storm Stryker Case
LiteOn iHAS124 24X Internal DVD Writer with SATA
Corsair 1000W RM1000 G2 Power Supply
Kingstone HyperX 120GB SATA SSD
2) Intel Core i7 6700K CPU
ASRock Z170 Extreme4 Socket 1151 Motherboard
Hyperx Fury Black 16GB DDR4-2133MHz
For the GPU I'm leaning towards a Radeon R9 Fury X if either AMD or Nvidia fail to come up with something special to beat it before then for around the same price. I'm looking at an AMD card because of AS and the insane memory bandwidth as well as their LiquidVR and Virtual Super Resolution features.
But for now my main choices are option number 1) or option number 2) above. Option number 2) works out at around £50-60 more expensive but obviously has the advantages that the Skylake architecture and higher speed DDR4 give it, which I would imagine would be a good thing when gaming in VR.
I'm going to be using it primarily for gaming and VR gaming but have also started to mess around with creating 3D models too so I reckon an i7 CPU will be better than the cheaper i5 versions of each CPU.
So will option 1) be okay for VR gaming goodness or is it worth spending an extra 50-60 quid to get option 2)..?
Thanks in advance for any help!
