two computers two monitors single kb/mouse
3 Mar 2010
Surrey
Hi guys,
I am after something which will allow me to use a single USB keyboard/mouse along with a dual monitor display between two computers without changing the cables around.
Obvious firstly a KVM would come to mind, however for a dual monitor KVM with usb support is almost £200 is there any cheaper solution?
A monitor for each is not a solution :P
Thanks.
2 KVM's? Just remember to switch both at the same time. You could get 1 manual, and one automatic. Especially as the second can just be a crap one since it doesn't need usb support.
you could go for a switch for the monitor and http://www.inputdirector.com/downloads.html for the keyboard and mouse. The software allows you to use 1 keyboard and mouse in PC1 to control both PC1 and 2 over your home network. Leaving you just needing a monitor switch. The software detects when you move the mouse to a area of the monitor or vis a hotkey and then switches the imput to the other PC. No need for a KVM just let your LAN handle the keyboard and mouse imput.
Heres a guid to setting it up. Multi monitor support and also share your clipboard for copy/pasting files over you network. If it looks dated there was a BETA released in February.
Hope this works out a lot cheaper.
Good idea, however I have one plug socket left and would rather not have a third extension lead.
Howeverthis maybe my only option.
I do have one thing to mention, my monitors both have two inputs DVI and VGA I can switch between them by pressing a button on the monitor.
Would a VGA>DVI adaptor make the VGA port appear at 1920x1080? and look the same as it would as if it were a DVI port?
cant guarnetee it'll look the same.
it really depends on the gpu and monitor
some monitors have poor vga connecters, some have decent ones, etc
best just to try it and see
vga will do the rez fine thou
Winner what you lose isnt worth mentioning unless you really need the 3ms response time on the refresh rate. What model are your monitors check what res they support under VGA.
