Two cores on my 2600k run hotter, never noticed it before. Any reason for concern?
21 Aug 2009
Just opened speccy and noticed that cores 0 and 1 are idling at 27/28 while 2 is at 34 and 3 is at 36/7.
Any reason to be worried? Everything was fine the last time I checked.
It's normal
What is more important is what the temps are under load, you will still get a variation the same as you do at idle. Just make sure none of the cores are getting too hot.
