- 28 Oct 2002
Hi,
I have two loops running in my external cooling tower - one powered by an Iwaki (for the CPU and GFX) and one by a dual DDC pump arrangement (for the SCSI, chipset, voltage regulators and RAM).
The dual DDCs seem not to generate enough pressure to push the coolant through the multiple radiators and the blocks and I am thinking of adding a D5 vario pump to correct this.
My question is - would I be best served removing the dual DDC and replacing with the more powerful D5 or adding the D5 in series?
It would be a pain to remove the DDCs as they are mounted in the tower, but if their presence would hinder performance I would be forced to reconsider.
THANKS
THANKS
You can't argue with Ohms's Law.
