Hi Guys
We have some epic new cases on route from Antec.
First up is the P100 Mid Tower. This is a perfect case for silent computing. Building on the foundations of Antec's classic Silent series chassis.
The interior of the case is roomy and uses substantial sound deadening materials. There is room for loads of storage drives and the option to use the top panel as a vented area.
Second up is the ISK 600. This case is outrageously good quality. Ace Modder came in this morning with a sample of this and the P100 and the ISK is my favourite without a doubt.
Lots of room and a classy brushed aluminium exterior makes this an ideal small form factor choice.
I really like the reset and power button designs that Antec are using in these new cases. very unique and classic. Certainly a brilliant choice for anyone in the market for these very specialised cases.
Antec P100 Mid Tower Silenced Computing Case @ £74.99 inc VAT
The P100 is an ATX case that epitomizes cool, quiet, and sophistication. It features Antec’s award winning the Performance One series design and Quiet Computing™ technologies that minimize system noise.
In addition to 7 expansion slots, the P100 also supports 2 toolless 5.25” drives and 7 tool-less 3.5”/ 2.5” drives. With a greatprice to feature ratio the P100 is the only economical case that delivers first class silence performance. A balance of price and feature is achieved by integrating Antec design with superior build quality. Engineered with Quiet Computing™ Technology, the P100 is truly in a class all its own.
Features:-
- Compatible with up to 3-way NVIDIA SLI/AMD CrossFireX.
- Complete dual layer design: steel and foam panels deaden noise.
- Grommet-lined cable routing holes with 20mm of space behind the motherboard
tray
- 2 front panel USB3.0 ports
- 7 quiet 3.5h/ 2.5h drive bays utilize trays with preinstalled silicone grommets
- 2 tool-less 5.25h drive bays
- Advance cooling solutions with top mounts spaced for 240mm radiators
- Includes two silent 120mm fans with fluid dynamic bearings
- PSU intake & front air filters
- Advanced cooling system: includes 2 fans and 3 additional fan mounts
- Sleek front bezel with double-hinged door: open up to 270 .
Specification:-
- Product Name: P100
- Model: AQP100BA
- Form Factor: Mid Tower
- Motherboard Support: ATX, Micro ATX, Mini-ITX
- Material Syntheticmaterial and 0.6mm Steel plate combination
- Expansion Slot: 7
- Dust Filter(s) 1 x front + 1 x bottom
- Max CPU cooler height . 6.7h / 170 mm
Drive Bays
- 2 x 5.25" tool-less
- 7 x 3.5" / 2.5h tool-less HDD bays
Cooling
- 1x 120/140mm Front intake fan
- 2x 120/140mm Top exhust fan mounts
- 1x 120mm rear exhaust fan mounts
Included Fans
- 1 x 120mm Front FDB fan, 1200 r.p.m 18dB(A)
- 1 x 120mm Rear FDB fan, 1200 r.p.m 18dB(A)
I / O Ports
- 2 x USB 3.0
- 2 x USB 2.0
- 1 x Audio I/O ( AC97 & HD Audio)
- PSU mounts ATX/ EPS standard
- Cable Management Extra large cable routing space …20mm
- Dimensions (H*W*D) 484 * 220 * 523 (mm)
Only £74.99 inc VAT.
ORDER NOW
Antec ISK 600 Small Form Factor ITX Chassis @ £64.99 inc VAT
Sophisticated and Durable: The ISK600 is the newest addition to Antec’s award-winning ISK line of Mini-ITX cases. It is a versatile enclosure that matches any CEO’s desk, designer’s office, or family living room.
It is designed exclusively for Mini-ITX motherboards and barely takes up desk space at 260 mm (10.3 inches) by 369 mm (14.6inches).
In addition to continuing Antec’s tradition of solid construction by using 0.8mm SECC steel, the ISK600 features elegantly designed brushed aluminum top and side panels. It will last for builds to come with space for a 12.5” graphics card, 2 expansion slots, and three drive bays. Discover the power of the ISK600.
Features:
- Compatible with graphic cards up to 12.5” (317.5mm).
- Includes one silent 120mm rear fan with fluid dynamic bearings.
- Integrated LEDs are carefully calibrated to achieve optimal color and brightness.
- Advance cooling design ready for liquid cooling configurations.
- Compatible with all ATX standard power supplies(140 x 150 x 86mm)
- Stylish and sturdy brushed aluminum panels bring subtle elegance to your build
Specification:
- Material 0.8mm Aluminum & 0.8mm Steel and Synthetic material
- Graphic card size …12.5h (317.5 mm)
- Cooling System 1 x 120 mm Rear Fluid Dynamic Bearing FDB fan, 1200 r. p. m, 18dB(included)
- Maximum CPU cooler height …170mm
- Drive Bays
- 1 x slim optical drive bay
- 2 x 2.5g HDD bays
- 3 x 3.5h HDD bays
- Top Ports, 1 x USB 3.0, 1 x USB 2.0, 1 x Audio I/O (AC97 & HD Audio)
- Expansion Slots 2
- Motherboard Support Mini-ITX
- PSU mounts ATX standard PSU with 140 x 150 x 86mm
- Dimensions H*W*D 195 * 260 * 369mm
Only £64.99 inc VAT.
ORDER NOW
Features:-
tray
Specification:-
- Model: AQP100BA
- Expansion Slot: 7
Drive Bays
Cooling
Included Fans
I / O Ports
- 2 x USB 3.0
- 2 x USB 2.0
ORDER NOW
Features:
Specification:
- Drive Bays
- 2 x 2.5g HDD bays
- 3 x 3.5h HDD bays
- Expansion Slots 2
ORDER NOW
