- 2 Dec 2006
Hey, well basicaly ive just noticed two sort of streak lines down my screen. Its nothing on the screen and is definitly either a problem with my graphics card or the screen its self but im insure how to further test or even fix. I gues the best way i could discribe them would be slightly more shaded/blury lines quite thin. They are very noticeable on dark backgrounds though.
Cheers
:EDIT:
Just relised i can plug my laptop into it ill check tomorrow. Do you recon i could get a replacement from benq being that it isn't like in your face ?
Cheers
:EDIT:
