*****TWO Fantastic Sandybridge CPU + MOBO Bundles!*****
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Anyway I promised you guys two bundles first thing, I've hit your price targets making us the cheapest in the UK, check them out:-
OcUK Motherboard Bundle - Intel Core i5 2500K & Asus P8P67 Intel P67 Mainboard @ £299.98 inc VAT
Our motherboard bundles are designed using all compatible components to prevent you our customers the confusion of working out what workds together.
The main specifications of this bundle are: -
- Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
- Asus P8P67 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge)
Every bundle comes with a processor and heatsink/fan, all is designed to work together in harmony, all you need to do is the simple process of inserting the CPU, fitting the cooler and installing your chosen memory.
Technical Specification of components:-
Processor:-
- No. of Cores 4
- Supports Virtualisation Yes (VT-x)
- Architecture Features 32nm
- Cache 6Mb
- Clockspeed 3.30Ghz (3.70GHz with TURBO)
- Manufacturer Intel
- Intel reference cooler
- Unlocked Multiplier
Motherboard: Asus P8P67 Intel P67 Mainboard
Key specification:
- ATX Form Factor
- LGA1155 socket for Intel® 2nd Generation Core™ i7/ Core™ i5/ Core™ i3 Processors
- Intel® P67 Express Chipset
- PCI-E x 16 Single x16 or x8x8x4
- Supports ATI® Quad-GPU CrossFireX™ Technology
- 4 x DDR3, up to 32.0GB
- 8-CH HD audio
- Gigabit LAN controller
- 2 x USB 3.0 ports at back panel (blue)
- 2 x USB 3.0 ports at mid-board for front panel support
- 12 x USB 2.0 ports (6 ports at mid-board, 6 ports at back panel)
- 2 x SATA 6.0 Gb/s ports (grey)
- 2 x SATA 6.0 Gb/s ports (navy blue)
- 4 x SATA 3.0 Gb/s ports (blue)
- Bluetooth v2.1 + EDR
- 2 x IEEE 1394a ports
In The Box:
- 1 x 2-port USB and eSATA module
- 2 x Serial ATA 6.0Gb/s cables
- 2 x Serial ATA 3.0Gb/s cables
- 2 in 1 Q-connector
- User's manual
- Warranty: 3 Year
See related products for Sandybridge compatible memory and coolers.
Only £299.98 inc VAT.
ORDER NOW
OcUK Motherboard Bundle - Intel Core i7 2600K & Asus P8P67 Pro Intel P67 Mainboard @ £399.98 inc VAT
- Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor
- Asus P8P67 Pro Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge)
Processor:-
- No. of Cores 4 (8 with hyperthreading)
- Cache 8Mb
- Clockspeed 3.40Ghz (3.80GHz with TURBO)
Motherboard: Asus P8P67 Pro Intel P67 Mainboard
Key specification:
- ATX Form Factor
- PCI-E x 16 single x16 or x8x8x4
- Supports NVIDIA® Quad-GPU SLI™ Technology
- 8-CH HD audio
In The Box:
- 4 x Serial ATA 6.0Gb/s cables
- 1 x ASUS SLI bridge connector
- 1 x ASUS USB 3.0 Bracket
- ASUS Q-Shield
- User's manual
- Warranty: 3 Year
Only £399.98 inc VAT.
ORDER NOW
Is this the actions of someone who has no respect for their forum members? :)
I was trying to work out the differences between them as you've got the following in the specifications for the 2600K bundle :p
Is the spec correct that the Asus P8P67 Intel P67 doesn't have any PCI slots? I ask as the H67 version does according to its spec...
If that is correct, the 'you may also be interested in' that comes up for the Asus P8P67 Intel P67 is a bit misleading - it's a PCI sound card!
They do have PCI slots. :)
>_< got me excited for a moment there; I'm looking to buy an Asus P8P67 Pro with a 2500k, any chance of a bundle? maybe a special deal just for me :D hehe
is this the pro version of motherboard on the £299 bundle? one place is doing the pro and i2500k for £311.99
How long is this deal on for?
Seriously liking it but can't really order till friday.
I shall hold this pricing until end of this week, but these CPU's are about to go in massive constraint as in no stock for weeks, so due to that prices will go up end of this week, so if you want a Sandybridge and were bargain hunting these two bundles are a very good deal.
We won't be offering any other bundles, just these two. :)
Nope, its the standard board. :)
Thats a good deal from the other place and I'd suggest you buy it if they have stock. :)
Don't believe its the Pro but considering the mobo and CPU bundle actually costs a couple of quid less than the CPU + LE version of the mobo (most 'basic' I believe) then its a great deal.
Practically a free upgrade from the 'base' P8P67 LE mobo.
Ye good deals :) but I want 2 way SLI + dedicated physx so I need the pro >_< the evo would also work but its more money for a few extra features I don't need.
Yep I'm after the Pro board as well with the 2500k seems thats the popular choice, and afraid it's cheaper on NO COMPETITORS, I went there by mistake thinking it was here and noticed it's way cheaper on boards and CPU's..am afraid. I'd rather buy from Overclockers though :( C'mon lads the 2500k is way overpriced can't you do it without the game?
So Cheeky :eek:
They don't currently have any stock tho so its easy to have the best price in the world but without any stock its meaningless frankly.
I ideally want a 2500k with a p8p67 pro, but would consider a 2500 if the price was right and the stock was ready to ship, there is a place that has just this to pre order but I don't fancy waiting the estimated 3 - 4 weeks >_<
Is the 2500k CPU really likely to be out of stock for weeks once this initial batch is sold? Was hoping to leave it for a week or so before ordering my CPU just to let things settle down and see what stability is like but I don't wanna miss the boat and end up without a CPU for weeks on end! Would be unusual wouldn't it to have an initial batch and then no follow up stock for weeks? Does it suggest Intel are playing things safe and ensuring the chips are ok before re-supplying retail or am I reading too much into it?
Cheers
Andy
Well it's true been looking for ages to upgrade from my 3 year old dual core and spending over £1k on bits so gota get the cheapest price but I was always under the impression this site gave the best support. But every component I have price matched is more here now, will you guys price match?
