Caporegime
- 30 Jul 2013
I am moving to a property which can only get fibre broadband at the moment.
It already has one line connected which will be active on Friday, but is quite limited in speed and I'm used to full FFTP
I assume it's perfectly possible to get another line to the house for an additional fibre connection?
What's the best way of doing it. At the moment I use 2x ASUS AX88u routers in 'aimesh' mode.
I assume they can only take one broadband connection each? (as opposed to both connections going in to the same one)
Is there a way to run a system like this with just one WiFi connection (like the mesh) or would each router then be sending its own WiFi network?
Just appreciate a bit of advice.
Sadly the house isn't in a 5g area so I can't use mobile broadband.
For all I know it'll have FFTP in 6 months but at the moment they are just saying 'by 2025'
