- 5 Jan 2005
Hi,
I currently have three LCD screens, which I run off two AMD cards (not in crossfire mode).
Basically I use my 6950 on my primary monitor (gaming etc..) and the Cheaper AMD card for running the other two monitors.
I came across a article (cant seem to find it now), that stated, considering my one card can run all three monitors easily, there is no benefit of the second card, as its only used for the connectors and all video data (2d etc..) is processed by primary card and passed through to the second card connectors.
The only reason I have this setup is because when I play games, I want the two other monitors to stay on so I can see my skype/chat/browser window etc... while playing, and also when I alt+tab out its very fast.
So if there is no benefit should I just connect everything the 6950?
Also my main reason for asking is, because, I have BF3
and it plays well only problem i get is random map will give me artifacts/issues and i have to reboot the system, I am on the latest 11.10 preview 3 drivers and so the only thing I can assume is that the other card is causing some sort of issue.
any advice/info would be appreciated.
System specs is as follows:
Intel i7 3Ghz
12GB mem
XFX AMD 6950 2GB + ATI 3470 (dual display port)
and it plays well only problem i get is random map will give me artifacts/issues and i have to reboot the system, I am on the latest 11.10 preview 3 drivers and so the only thing I can assume is that the other card is causing some sort of issue.any advice/info would be appreciated.
Intel i7 3Ghz
12GB mem
