Install Virtual Box and a copy of Windows/Linux as a guest OS. Run it on the other screen and tell Virtual Box to connect the second mouse directly to the guest OS via the Virtual Box USB options. Run this VM on your second screen and there you go, job's a good'n - two desktop environments on one PC.Is there no way of having multiple cursors?
The Microsoft EasyBall used to enable two cursors on one screen, it was designed for teaching kids how to use a computer.
So you could always downgrade to Windows 95 and get one of those![]()
The Windows MultiPoint SDK is designed to work on Windows Vista (32-bit) or on Windows XP SP2 (32-bit)
Hope this helps![]()
I do wonder...but multiple mice? what's the point?![]()
If that's your intention I should emphasize that my suggestion will result in one mouse per operating system, just with two operating systems on the same hardware.
