** TWO INCREDIBLE CLEARANCE BARGAINS! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
I've got two bargains here, these are un-wanted or manufacturer repaired, can't be clearer but you still have DSR protection. So check these out, stock is extremely limited:-
**B Grade** Dell UltraSharp U2711 27" Widescreen LCD Monitor - Midnight Grey (MO-051-DE) @ £399.98 inc VAT
With its amazing colour accuracy and versatile connectivity, the high-performance Dell U2711 Monitor delivers stunning detail, depth and responsiveness. PremierColour technology allows the Dell U2711 Monitor to deliver reliable, true-to-life colour without the need for extensive calibration. 12-bit internal processing enables 1.07 billon colours and helps distinguish very low grayscale tones to deliver greater level of details in dark areas. Factory-tuned Adobe RGB and sRGB modes minimize the need for further colour calibration; each monitor arrives with a certified colour-calibration factory report. 100% sRGB and 96% AdobeRGB meets the needs of professional users involved in colour-centric work such as graphic design, CAD/CAM, gaming and media creation.Customize your viewing experience with the height-adjustable stand and tilt/swivel features - or save valuable desktop space by detaching the panel from the stand for wall mounting.
- Height Adjustable
- Swivel & Tilt Stand
- Screen Size: 27" IPS Widescreen
- Resolution: 2560x1440
- Contrast Ratio: 80000:1
- Brightness: 350cd/m²
- Response Time: 6ms
- Viewing Angles (H/V): 178°/178°
- Colours: 1.07 Billion
- Inputs: 1x Analogue, 2x DVI-D, 1x HDMI, 1x DisplayPort, 1x Composite & 1x Component
- 4-Port USB Hub
- 8-in-1 Card Reader
- VESA Compliant
- Dimensions: 646.71mm x 427.83mm x 199.95mm
- Weight: 7.72kg
- Warranty: 1 Year Return to base (OcUK)
- Factory re-packed
Was [£559.99] Inc. VAT
Only £399.98 inc VAT.
ORDER NOW
**B Grade** Samsung S27A950D 27" 120Hz 3D Widescreen Ultra Thin LED Monitor - Glossy Black @ £399.98 inc VAT
Samsung’s 750 and 950 series 3D desktop 3D monitors feature high refresh rate, incredibly thin bezel and stylish design. These monitors are able to analyze and render 2D content in real-time to 3D, supporting PC content, Blu-ray films and gaming consoles. The monitors feature a built-in glasses sync emitter, and they are packaged with a pair of 3D active shutter glasses.
Viewers will experience deep, rich colours and image clarity with Samsung’s new Ultra Clear Panel technology, which combines the vibrancy of a glossy display while maintaining the ease of viewing afforded by an anti-glare matte finish. The LED-backlit panel boasts 100% sRGB coverage to produce realistic colour reproduction.
Features:-
- 3D Active Glasses are included
- TRUE 120Hz
- 2D - 3D Conversion technology
- Screen Size: 27" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 10000000:1
- Brightness: 300cd/m²
- Response Time: 2ms (2D) / 2ms (3D)
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x HDMI, 1x DisplayPort, 1x Dual Link DVI
- Warranty: 3 Years On-Site
Was [£599.99] Inc. VAT
ORDER NOW
