HI there
Two incredible deals on 8GB Memory kits at OcUK Today:-
Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PV38G160C9K) @ £23.99 inc VAT
Patriot Memory’s Viper 3 Series memory kits are designed with true performance in mind. Tested and compatible with Intel’s® and AMD’s DDR3 compatible processors and chipsets, The Viper 3 series provides the best performance and stability for the most demanding computer environments.
The Viper 3 series utilizes a custom designed high performance heat shield or superior heat dissipation to ensure rock solid performance even when using the most taxing applications. Built from the highest quality Build of Materials, Patriot Memory’s Viper 3 Series memory kits are hand tested and validated for system compatibility.
Available in dual and quad channel kits, 8GB, 16GB and 32GB Kits, Patriot Memory’s Viper 3 Series will be offered at speeds from 1600MHz up to 2133MHz at 1.5 volts and are XMP 1.3 eady. Hand tested for quality assurance, the Viper 3 series is backed by a lifetime warranty.
- Extreme Performance PC3-12800 (1600MHz)
- Low Latency (9-9-9-24)
- Voltage: 1.5v
- XMP 1.3 Ready
- Equipped with an extruded aluminum shield build around a copper core to provide improved cooling
- 100% Tested and Verified
- RoHS Compliant
- Tested on Intel® P67 and Z77 platform
Was [£31.99] Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) @ £23.99 inc VAT
Kingston's KHX1600C9D3X2K2/8GX is a kit of two 512M x 64-bit 4GB DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 8GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.<br>
<br>
Model Name: KHX1600C9D3X2K2/8GX<br>
Main Board: INTEL<br>
System: DESKTOP<br>
System Type: DDR3<br>
M/B Chipset: INTEL P67<br>
CAS Latency: 9-9-9-27 2N<br>
Capacity: 8GB (4GBx2)<br>
Speed: DDR3-1600 (PC3-12800)<br>
Test Voltage: 1.50-1.65V<br>
Registered/Unbuffered: Unbuffered<br>
Error Checking: Non-ECC<br>
Type: 240-pin DIMM<br>
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)<br>
Master Pack Weight: 0.26 lbs<br>
Black PCB<br>
Warranty: Lifetime<br>
ORDER NOW
- Voltage: 1.5v
- XMP 1.3 Ready
- RoHS Compliant
ORDER NOW
<br>
System: DESKTOP<br>
Black PCB<br>
ORDER NOW
