Two inputs to one monitor can you split the screen
5 Aug 2013
Shropshire
I have just installed a NVR and used HDMI to my second monitor which is connected to my PC by DVI
I just use the screen menu to change inputs to have a look at camera or PC whichever I want-
Question is can the screen be split to show both input's at same time ??
Trouble with screen menu it only stays there for a few seconds and it's not long enough to read what's there.
Monitor is iiyama E2473HS
Thanks
You'd need PbP (Picture-by-Picture) or PiP (Picture-In-Picture) support to display the inputs from more than one source at the same time on the display - from a quick look doesn't seem like PBP is supported on the E2473HS.
One option would be to input the NVR via a HDMI capture card on the PC which would then display the image in a window on your desktop.
