Two Monitor Sim Set Up
27 Mar 2016
Bristolian living in Swindon
Hi all
Looking to build myself a pretty basic simulator set up but I have a few questions..
Is there a need for a stronger power supply?
Do the monitors have to be the same?
Is there minimum specs to run double screen?
Current specs:
Intel i3-8100 stock cooler
Gigabyte z370p d3
8gb DDR4 2133mhz
Asus GTX760
XFX XT 500w PSU
1TB HDD
I'm on a budget but its something ill be doing this year at some point, no rush
Probably wouldn't want to game on a GTX760 and not dual monitor gaming.
i3 might also struggle with a simulator game. Minimum would be a decent I5.
having 2 monitors the same would look a lot nicer as they will have the same colours, would make the experience more enjoyable in my opinion. Different monitors would be okay for gaming on just 1 of them.
Also are you gaming over multiple monitors? generally 3 monitors is what you would go for, if you had the budget.
Whats your budget?
