Hello, basically im about to purchase two monitors, and hooking them up to my computer will i need any extra cables or anything to set up duel screen or does everything i need some with the monitors already?
Should be fine, you will need 1 DVI and 1 VGA cable. I don't know if its the same these days but multi monitor use to 1/2 the performance while gaming.
Have you thought about Eyefinity or a Single "Good" Monitor?
and that graphics card doesnt appear to be one of the options
i've now decided to go for IPS panel monitors because they are better for what im doing so i've chosen to buy two of these monitors;
it doesnt say anything about getting the cables with it so i might have to buy 2 of those you mentioned above, but won't that need two DVI slots on my graphics card? it only says it has 1
