Two monitors
Use your motherboard+CPU,
Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
Maximum shared memory of 1696 MB
Supports Intel® HD Graphics
In case it's not for the machine in your sig, pretty much any GPU since PCI-E became the standard can run 2 monitors happily. If it's not for gaming, choose the cheapest GPU you can find with the right connectors for the screens you want to use - Nvidia GT210 / GT610, or AMD 5450 / 6450 look to be the cheapest cards you can still buy brand new.
