UPDATED: Two motherboards, one problem.
Last April I assembled a system consisting of i7-2700K CPU, Arctic i30 cooler, GA_Z68X-UD3-B3 r.1.0, 8GB (2x4Gb) Corsair Vengeance 9-9-9-24, 1.5v 1600mhz RAM, OCZ-ZS750W PSU and Nvidia GTX 295 GPU. The system run without issue until the start of 2013, when I flashed the BIOS to U1e(UEFI BIOS) on 2/1/13 - the system restarted without incident and was used for several hours.
When I returned to the system the following morning it was frozen on the shutdown screen i had started the previous evening. I powered the system off at the wall and then tried powering up. The system was completely dead. On opening the system I observed that the CPU fan would briefly spin (just a few revolutions) and then stop. I removed all connections to the board except PSU, GPU, 1 stick of RAM - there was no difference. I then tried changing the PSU with a known good one from another similar system. No change. I then changed the RAM with various known good sticks. No change. I tried another known good GPU, PSU and RAM. No change.
I then purchased a new motherboard - assuming that it was more likely to be a MB fault than CPU fault. When the new MB arrived - a GA-Z68AP-D3 r.2.0 - the same fault was observed. After swapping through known good components, I assumed that CPU was at fault, and Intel's support team agreed. My CPU was exchanged for a brand new one by Intel. Today, I have just installed the CPU in both of the boards and the same fault - not powering up, just a brief spin of the CPU fan and a flash of the PHASE LEDs and stops. As all the other components are known good, I wonder if both motherboards are faulty. Experience tells me that CPU faults are rare compared with MB faults - so I suspect that is likely. I don't have access to another 1155 known good motherboard to check that the replacement CPU from Intel is good. I have also tried clearing the CMOS and removing battery for ten minutes as suggested by Gigabyte, no joy.
So can anyone think of anything else I can try before I RMA both motherboards?
