Hi Guys
I think we all know by now that Zowie know a thing or two about mice.
Their latest surface sees some improvements to the base meaning it grips the desk better. The top surface is optimised for use with performance mouse sensors and it is incredibly accurate.
Pre order right now, stock should be here very soon.
Zowie P-SR Medium Soft Surface Mousepad - Dark Grey @ £14.99 inc VAT
Starting in 2010, we found that it would be an extremely hard mission to create perfectly flat mouse pads due to the quality of raw material of natural rubbers. But in 2011 we released the G-TF Speed and CM Series with a newly designed rubber base, guaranteeing 100% flatness.
The new base of the G-TF Speed and CM Series is good, but it's slightly harder in comparison to the traditional cloth mouse pad. We understand the need of gamers who prefer to use a cloth pad with a soft base. After years of development and testing we have finally found the answer - a new ZOWIE GEAR rubber base was born and will be put to use in our new SR Series.
Specification:
- The smooth and even texture offers a consistent and comfortable glide
- Newly designed rubber base offers increased stability on any surface
- 100% compatible with all types of mice
Dimension:
P-SR: 355 x 315 x 3.5 mm / 14.0 x 12.4 x 0.14 inch
Only £14.99 inc VAT.
ORDER NOW
Zowie G-SR Big Soft Surface Mousepad - Dark Grey @ £21.95 inc VAT
Specification:
Dimension:
G-SR: 480 x 400 x 3.5 mm / 18.9 x 15.7 x 0.14 inch
Only £21.95 inc VAT.
ORDER NOW
Specification:
Dimension:
ORDER NOW
Specification:
Dimension:
ORDER NOW
