I'm considering upgrading to a Ryzen-based system before the end of the year, most likely with a 3700X CPU, an X570 motherboard and 32 GB of 3,600 mhz RAM.
From what I have read it seems that two sticks of RAM runs a little faster than four on an X570 but on the other hand single rank 8 GB sticks can be got with tighter timings than dual rank 16 GB ones. I've seen 32 GB two-stick kits with CAS 17-19-19-19-39 timing and a bit dearer four-stick kits with CAS 16-16-16-36 timing.
My question is, assuming both sets will run at 3,600 mhz at the advertised timings would I gain more from the tighter timings than I lose from running four sticks instead of two?
