Two PC's one monitor
24 May 2012
One VGA to find them, One Monitor to bring them all, And in the darkness bind them :p
Geeky puns aside:D I'd like to connect two PC's one monitor, what is the cheapest solution under £10, a KVM Switch or a D-SUB splitter although the cables would need to be very long?
I have no need two run two computers at once, it's merely to save me the energy of switching the VGA input from one computer to another, every time I my sister needs to use the old PC.
The monitor in question is an old LG L204WS-SF 20 inch Widescreen TFT.
Screen Size: 20"
Screen Resolution: 1680x1050
Response Time: 5ms
Brightness: 300cd/m2
Contrast: 2000:1
Main Specifications:
Product Description: LG L204WS-SF - flat panel display - TFT - 20"
Device Type: Flat panel display / TFT active matrix
Colour: Silver
Dimensions (WxDxH): 46.6 cm x 22.6 cm x 38.4 cm
Weight: 5.5 kg
Diagonal Size: 20" - widescreen
Max Resolution: 1680 x 1050 / 75 Hz
Colour support: 24-bit (16.7 million colours)
Image Aspect Ratio: 16:10
Response Time: 5 ms
Image Brightness: 300 cd/m2
Image Contrast Ratio: 2000:1 (dynamic)
Signal Input: VGA
Compliant Standards: TCO "03, DDC-1, DDC-2B, EPA Energy Star, ISO 13406-2
Power Consumption Operational: 80 Watt
It as a D-SUB connection the graphics card is a GTX 670 DVI with adapter.
Side note must bug my sister to upgrade her monitor 1680 x 1050 with a GTX 670 madness.
images
THIS IS NOT MADNESS THIS IS A 2007 MONITOR!!!
Side note need to find something more productive to do with my time.
