: Two public networks on ASA outside interface
17 Oct 2002
West Midlands
Greetings, we have an MPLS network configured, the head office has a 10Mbit Ethernet circuit comming into the HQ which is split into two dot1q vlans. This link terminates on a 3825 ISR.
The internet vlan is bridged from the router onto the outside interface of the firewall which isnt a problem...however the ISP has provided two address blocks
A /30 for the dot1q Vlan internet link and a /28 for external business services such as SMTP.
Now currently i have the /30 terminated on the outside of the firewall, if i setup NAT statements on the firewall for the /28 range and get the ISP to route to the /28 network through the /30 network would this work ok.
If configs are needed please let me know.
We were going to use a common gateway initially but the customer wants both the firewall and router connected to the internal network, at present the /30 is bridged onto f0/0/0 which connects to the outside of the asa.
The other options i was considering was to assign the /30 address to g0/1.1001 being 193.***.***.170 255.255.255.252 and then assign the first avaliable address in the /28 range to vlan 1 then the next address in the /28 range to the outside of the firewall.
Code:
ASA
interface ethernet 0/0
ip address 193.***.***.170 255.255.255.252
nameif outside
security-level 0
interface ethernet 0/1
ip address 10.171.41.252 255.255.255.0
nameif inside
security-level 90
route inside 10.170.0.0 255.255.255.0 10.171.41.1
route inside 10.171.0.0 255.255.255.0 10.171.41.1
route outside 0.0.0.0 0.0.0.0 195.***.***.169
ISR
bridge irb
bridge 1 protocol ieee
interface GigabitEthernet0/0
no ip address
media-type rj45
negotiation auto
speed auto
duplex auto
interface GigabitEthernet0/0.1 - Connection to Customer Internal Lan
ip address 10.171.40.1 255.255.255.0
encapsulation dot1q 1
interface GigabitEthernet0/0.50 - Connection to Customer Internal Lan
ip address 10.170.40.1 255.255.255.0
encapsulation dot1q 50
interface GigabitEthernet0/1 - Connection to MPLS Circuit
no ip address
media-type rj45
negotiation auto
speed 10
duplex full
interface GigabitEthernet0/1.1000 - Connection to MPLS Network
ip address 172.18.255.2 255.255.255.252
encapsulation dot1q 1000
interface GigabitEthernet0/1.1001 - Connection to Internet
no ip address
encapsulation dot1q 1001
bridge-group 1
interface FastEthernet0/0/0 - Connection to ASA Outside interface
speed 100
duplex full
interface FastEthernet0/0/1
speed 100
duplex full
interface FastEthernet0/0/2
speed 100
duplex full
interface FastEthernet0/0/3
interface vlan 1
no ip address
bridge-group 1
ip route 0.0.0.0 0.0.0.0 10.171.40.252 - ASA Inside interface for MPLS Remote site to Internet Traffic
ip route 10.171.0.0 255.255.255.0 172.18.255.1 - Route to all other remote sites via PE
ip route 10.170.0.0 255.255.255.0 172.18.255.1 - Route to all other remote sites via PE
Regards
An interesting question actually, I don't really know. As I understand, what you're suggesting is your ISP routing the /28 to the IP from the /30 configured on your ASA, then running NAT on that interface for the /28. I've never tried it and it sounds potentially problematic (bear in mind here, I'm not a fan of Cisco security hardware so I'm not an expert on the ASA).
My approach would likely be to forget about the /30, it seems pointless, by configuring the /28 gateway IP on the ISPs side and another IP from the range as the physical interface IP on your ASA you'd still have 15 IPs left useable for NAT and you can just forget about the /30. It's also nice and simple and will certainly work. If you need the extra IP then just get a /27 from your ISP instead, they can't charge you any more for it, you just need to provide justification for the extra IPs.
Cheers for the reply, ive been doing some digging, i think that this would work as the firewall would start using proxy arp once the NAT statements for the /28 network are in place.
Ive got to speak to the isp tomorrow anyhow as currently the /30 address is reachable but there isnt a route on the isp side yet for the /28 network.
Regards
