Right I've been looking around the net but I can't seem to get a definitive answer.
What I'm trying to do is I guess 'bridge' two networks together so I can see computers on the network not on my immediate network (router).
I have two routers setup individually, both are WRT54G routers, both work great independently. Now I know if I just simply put a ethernet cable from one router to the other things will start to screw up because of the DHCP conflicting all over the place.
I've been trying to follow this guide >> http://www.chriscraig.net/blog/2007/01/04/two-isps-one-network/ but I start to run into problems just setting up one router manually, disabling the DHCP seems to start making things difficult.
I am manually able to setup my NIC so it can see the router gateway 192.168.1.2 and so I am able to change settings on the router, but then I can't get onto the Internet, a WAN IP still shows up under the status tab.
I'm so confused! I must be doing something wrong. Any help would be greatly appreciated.
