two sound cards to have the same audio output?
24 Jan 2007
hi
is there away to get two sound cards (ati's 4850 onboard sound + X-Fi XtremeGamer) to output at the same time with the same audio?
hi
Can i ask you why you want them to output the same audio? What exactly are you trying to achieve?
I used to have my SB Live on at the same time as onboard sound for Virtual DJ so its def possible, but with the same audio Im not so sure.
If the same thing is going to be outputted to 2 amps then why not simply use an adapter which will split the output from one card in two?
I think it might depend on the software. Most progams will probably only use one soundcard, depending on which one is the OS default.
